Suspension & Brakes Theory, alignment, spring rates....
ABS sensor?
Old Jul 5, 2009 | 02:41 PM
VR4ownzU's Avatar
Default ABS sensor?
How do I figure out which ABS sensor is bad when the ABS light comes on in a 99 Integra GS?
Old Jul 11, 2009 | 01:00 PM
hatchling37's Avatar
Default Re: ABS sensor?
Hook a scanner up to your OBD port, that will actually tell you which circuit it's having an issue with.
Old Jul 17, 2009 | 08:33 AM
unusual71's Avatar
are you familiar with pulling codes for CEL? there is a connector under the dash on the right side of the car and if you put a jumper across the two wires then when you start the car the codes will blink out.
manuelesr
Apr 13, 2008 01:08 PM
wrinkly
Jun 8, 2007 07:12 AM
rollercosta123
Nov 25, 2005 12:09 AM
alphabeatsco2004
Aug 16, 2005 07:28 PM
TerribleOne
Mar 19, 2003 10:59 AM
