Suspension & Brakes Theory, alignment, spring rates....
Bumpstop question
Old Feb 11, 2005 | 10:30 PM
RCautoworks's Avatar
Default Bumpstop question
I know how to cut them, just wondering if I am throwing on aftermarket springs with stock struts, do you need to cut them ? Or do you only need to cut them when your putting in aftermarket struts.
Old Feb 11, 2005 | 11:33 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Bumpstop question (90blackcrx)
You need to cut them when you "lower" the car. This keeps you from riding on them. Never use less than 1" of bump stop (I would use more though).
Old Feb 12, 2005 | 03:21 PM
Thanks, I found the instructions and Neuspeed springs are designed to use the stock bumpstops with out cutting them.
Old Feb 12, 2005 | 08:35 PM
civic_tuned's Avatar
Default Re: Bumpstop question (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">You need to cut them when you "lower" the car. This keeps you from riding on them. Never use less than 1" of bump stop (I would use more though).</TD></TR></TABLE>
if cut off the bumpstops wont it reduce the life the shocks by reducing shock travel by half an inch.
Old Feb 12, 2005 | 08:38 PM
turnbuckle's Avatar
Default Re: Bumpstop question (civic_type_r)
cutting the bump stops would increase pistol travel. if the pistons bottom out you will destroy the strut. keep atleast an inch of the bump stop.
Old Feb 12, 2005 | 08:50 PM
Default Re: Bumpstop question (turnbuckle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnbuckle &raquo;</TD></TR><TR><TD CLASS="quote">cutting the bump stops would increase pistol travel. if the pistons bottom out you will destroy the strut. keep atleast an inch of the bump stop. </TD></TR></TABLE>
With the neuspeed springs your suppose to leave the bunpstops stock, no cutting at.
Old Feb 13, 2005 | 03:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
With the neuspeed springs your suppose to leave the bunpstops stock, no cutting at.</TD></TR></TABLE>
You need to cut them when you "lower" the car. This keeps you from riding on them. Never use less than 1" of bump stop (I would use more though). by:94eg!
so which one is it?
Old Feb 13, 2005 | 03:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_type_r &raquo;</TD></TR><TR><TD CLASS="quote">
so which one is it?</TD></TR></TABLE>
Well I just bought neuspeed lowering springs and it tells me in bold letters not to cut them.
Old Feb 13, 2005 | 04:16 PM
s_i's Avatar
s_i
i didnt cut mine with sportlines.. no problems at all.. no noise. just shocks are blow now. after 3000 miles
Old Feb 14, 2005 | 06:54 AM
turnbuckle's Avatar
Default Re: (s_i)
what kind of struts do you have. if the spring rates are too high for the struts then the struts will wear out prematurely. OE struts or aftermarket OE type struts are usually not stiff enough to use with lowering springs.
-cory
Old Feb 14, 2005 | 09:42 AM
Default Re: (turnbuckle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnbuckle &raquo;</TD></TR><TR><TD CLASS="quote">what kind of struts do you have. if the spring rates are too high for the struts then the struts will wear out prematurely. OE struts or aftermarket OE type struts are usually not stiff enough to use with lowering springs.
-cory</TD></TR></TABLE>
There stock, and yes I am aware stock struts are not suppose to be used and I know it will make them wear down quicker.
Old Feb 14, 2005 | 09:54 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (90blackcrx)
I purchased my 94cx at 88k miles. I lowered it 2.25" at 100k with ground controls (400f/250r). At 150k, I put on some koni sports. All 4 of my OEM shocks were in good condition when I removed them. We do have pretty good streets here in vegas though (I drive carfully too)...
Old Feb 14, 2005 | 12:01 PM
Default Re: (94eg!)
On another note, those back bolts are horrible, ended up torching them out and had to buy new bushings. And I can't beleive Honda charges 8 bucks per bolt.
Old Feb 14, 2005 | 12:12 PM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">On another note, those back bolts are horrible, ended up torching them out and had to buy new bushings. And I can't beleive Honda charges 8 bucks per bolt.</TD></TR></TABLE>
Do you mean the LCA bolts that came on the car from the factory (if so, those do suck ***)?
Old Feb 14, 2005 | 09:35 PM
turnbuckle's Avatar
Default Re: (94eg!)
Do you mean the LCA bolts that came on the car from the factory (if so, those do suck ***)?</TD></TR></TABLE>
come on... you're in vegas. you can't pretend to know about the horrendous rust build up that we have to deal with on old cars up here in the northeast. my last CRX was an '89 from florida and you could take everything apart on that car by hand. two winters up here in new york and i was breaking out the torch just to get my tie rods to turn... ugh.
Old Feb 14, 2005 | 10:18 PM
Default Re: (94eg!)
Yep those are the bolts
come on... you're in vegas. you can't pretend to know about the horrendous rust build up that we have to deal with on old cars up here in the northeast. my last CRX was an '89 from florida and you could take everything apart on that car by hand. two winters up here in new york and i was breaking out the torch just to get my tie rods to turn... ugh. </TD></TR></TABLE>
Here is the weird thing, when I did mine on my 1990 crx and on my girlfriends 89 crx I did not have a problem with the bolts, I just did springs on a 2000 civic and I had a major problem. Even a torch was not getting the job down, I put 700ft lbs of torque on them and they just kept breaking sockets.
Old Feb 15, 2005 | 07:33 AM
94eg!'s Avatar
#1 Super Guy
Loved
You would think that, but those bolts are so ******* lame that even here in Vegas we snap at least 1 head off on every car...
Dry vegas weather does take good care of your cars though.
Old Feb 15, 2005 | 11:01 AM
POE's Avatar
POE
so which neuspeed springs did u get the race or the sports?
Old Feb 15, 2005 | 01:10 PM
Default Re: (Vtecin94dx)
The customer went with race, but I can get them all for the same price.
See sig
Old Feb 15, 2005 | 06:47 PM
POE's Avatar
POE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">The customer went with race, but I can get them all for the same price.
See sig</TD></TR></TABLE>
if u can belive i didnt cut my bumpstops eithor for my race springs with agx's and its not to bad, im planing on cuting them in half the next time i have it all apart again.
bopbop93030
Oct 28, 2008 07:02 PM
DFW
Suspension & Brakes
May 20, 2006 04:03 PM
LvN
Suspension & Brakes
Apr 22, 2006 03:52 PM
vipersr10
Feb 5, 2006 08:17 PM
GUNNER666
Jul 14, 2004 11:03 AM
