Suspension & Brakes Theory, alignment, spring rates....
Alignment Question????!!!!
Old Feb 18, 2005 | 03:16 PM
speedaholic92's Avatar
Default Alignment Question????!!!!
I'm getting my car aligned after a camber kit install tommorow. Will it make a difference if i were to align it with the stock wheels instead of the wheels i would be riding on later? As in the Toe or camber being affected by wheel size?
I have a 2000 Accord V6 on 16" Stocks right now for winter. I will be putting on some 19" wheels next month some time.
Old Feb 18, 2005 | 03:43 PM
nonsense's Avatar
Default Re: Alignment Question????!!!! (speedaholic92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedaholic92 &raquo;</TD></TR><TR><TD CLASS="quote">I'm getting my car aligned after a camber kit install tommorow. Will it make a difference if i were to align it with the stock wheels instead of the wheels i would be riding on later? As in the Toe or camber being affected by wheel size?
I have a 2000 Accord V6 on 16" Stocks right now for winter. I will be putting on some 19" wheels next month some time. </TD></TR></TABLE>
No it won't make any difference in the settings
Old Feb 19, 2005 | 04:57 AM
thanks for your help
Old Feb 19, 2005 | 06:06 PM
Jaesung's Avatar
i don't think the alignment would be an issue but your ride height would change with 19inch wheels.
Old Feb 19, 2005 | 06:41 PM
Evanmb44's Avatar
Default Re: Alignment Question????!!!! (Jaesung)
if you change the ride height i.e. bigger wheels the camber wouldl be affectd i would think
Old Feb 20, 2005 | 10:29 AM
nonsense's Avatar
Default Re: Alignment Question????!!!! (Evanmb44)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evanmb44 &raquo;</TD></TR><TR><TD CLASS="quote">if you change the ride height i.e. bigger wheels the camber wouldl be affectd i would think</TD></TR></TABLE>
no it wouldn't
Old Feb 20, 2005 | 02:28 PM
turbob18si's Avatar
Default Re: Alignment Question????!!!! (nonsense)
actually anytime ride height is affected camber is also affected
Old Feb 20, 2005 | 02:52 PM
Default Re: Alignment Question????!!!! (turbob18si)
so should i put on the 19" prior to alignment?? just to avoid any problems? CAN I GET A FOR SURE ANSWER???!!!
Old Feb 20, 2005 | 04:51 PM
J-J's Avatar
J-J
Default No Difference.
It makes no Difference.
Old Feb 21, 2005 | 07:34 AM
JimBlake's Avatar
Altering ride height by changing springs, yes camber & toe are affected.
But when you simply swap wheels, the suspension geometry isn't changed. The car may be sitting higher or lower, but the angle of the control arms isn't changed.
Old Feb 21, 2005 | 11:47 AM
nonsense's Avatar
Default Re: Alignment Question????!!!! (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Altering ride height by changing springs, yes camber & toe are affected.
This is correct. Altering spring length (thus loweing the car) alters the suspension geometry. Putting on larger tires doesn't do anything to the suspension geometry at all, so the toe and camber stay the same.
EP-tree
13
Nov 26, 2009 12:10 PM
Sypher
Suspension & Brakes
Dec 19, 2008 04:03 AM
slvrcvc93
19
Apr 30, 2008 11:52 AM
kevinm1981
Feb 8, 2008 05:04 AM
Infinity_Racer
Feb 18, 2004 10:43 AM
