Suspension & Brakes Theory, alignment, spring rates....
coilover adjustment wrench?
Old 09-28-2005, 04:05 PM
implayaz9's Avatar
Default coilover adjustment wrench?
i just got some GroundControl coils... and i lost the adjustment wrench.. do u guys know what can be used in order to adjust them or.. where can i get a wrench for cheap?.. please help
Old 09-28-2005, 07:49 PM
chinese acrobat's Avatar
Trusty flat head and a hammer. Allen key loosened first. Use some lube too.
Old 09-28-2005, 08:44 PM
jli18's Avatar
Default Re: (chinese acrobat)
get those cheap *** coilovers from ebay, they come with the wrench. u probably can get them for bout 50 bucks. think about it
Old 09-28-2005, 10:37 PM
EK k kay's Avatar
Default Re: (jli18)
You don't use a wrench on ground controls. There is an allen bolt that you loosen and then adjust with your barehands then tighten when you're done.
Old 09-28-2005, 11:03 PM
implayaz9's Avatar
Default Re: (EK k kay)
what size allen wrench do i need in order for me to loozen it?
Old 09-29-2005, 07:33 AM
civicholo's Avatar
Default Re: (implayaz9)
find a pack of different sizes and use the process of elimination. easy as that.
Old 10-31-2005, 10:05 PM
implayaz9's Avatar
Default Re: (civicholo)
i tried to losen it but i could not.. the place where to losen the coils is very hard... what could be done?
Old 10-31-2005, 10:13 PM
implayaz9's Avatar
help!!!
Old 10-31-2005, 10:52 PM
EK k kay's Avatar
Soak it in wd40 and turn the allen key as hard as you can. Once you get the bolt out, soak the threads with wd40 as well so it doesn't seize up again.
Skelley1980
05-04-2013 01:04 PM
KiNGDEE206
Suspension & Brakes
23
01-14-2013 11:19 AM
LukieLuc
03-20-2008 01:08 PM
george34
Suspension & Brakes
09-19-2005 02:13 AM
dc2monkie
Honda S2000
06-17-2004 08:59 PM
Quick Reply: coilover adjustment wrench?
