Suspension & Brakes Theory, alignment, spring rates....
Lowering Help !
Old Sep 27, 2005 | 06:54 AM
Royal_C!ty's Avatar
Default Lowering Help !
Hey guys just a quick question, I couldn't find a concrete answer in the archives so hopefully someone can just help me out. My question is
Can I lower/ "dump" my car and instead of purchasing a camber kit, just got get an alignment done and have them set the toe near 0 i believe ?
I'm just curious cause i'm itching to lower my car more but don't want my tires to get ate @ if you guys can help me out i'd greatly appreciate it - thanks justin
Old Sep 27, 2005 | 07:05 AM
ek9vboi2's Avatar
u can dump it to a point where they can still correct it to OEM spec. But if u do it extreme....u get what u ask 4. camber wear!
Old Sep 27, 2005 | 09:45 AM
Royal_C!ty's Avatar
Default Re: (ek9vboi2)
Thanks for the quick response, that's what i was thinkin is do OEM specs.
Bump for more help
Old Sep 27, 2005 | 10:21 AM
AutoXer's Avatar
Default Re: (eg8kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg8kid &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the quick response, that's what i was thinkin is do OEM specs.
Bump for more help </TD></TR></TABLE>
No, you don't want OEM spec. You want 0 toe.
After lowering my car a bit to add some camber before a track day, I measured my toe, and it was within spec (&gt;1/16 out). I didn't want to mess with it because I was being lazy. Got to the track, and noticed some feathering on the inside of my tires; set to 0, and haven't had a problem since.
Old Sep 27, 2005 | 11:22 AM
Royal_C!ty's Avatar
Default Re: (AutoXer)
alright so just have the toe adusted to 0 and i should be good w/ lowering the car more ?
Old Sep 27, 2005 | 11:32 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg8kid &raquo;</TD></TR><TR><TD CLASS="quote">alright so just have the toe adusted to 0 and i should be good w/ lowering the car more ? </TD></TR></TABLE>
Yes, you should be fine. Make sure you get before and after printouts at the shop.
Old Sep 27, 2005 | 08:14 PM
maachan's Avatar
How far can you lower before you need to have camber kit? 1inch? 2inches? More?
Old Sep 28, 2005 | 04:43 AM
AutoXer's Avatar
Default Re: (maachan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maachan &raquo;</TD></TR><TR><TD CLASS="quote">How far can you lower before you need to have camber kit? 1inch? 2inches? More? </TD></TR></TABLE>
I don't know about inches, but I'm running around 3* of neg camber (enough so you can see that there's alot of neg camber) and have no uneven wear issues.
Old Sep 28, 2005 | 04:59 AM
jay jay's Avatar
depends on your car but usually 1.5"-2.0" is where you will start to need a camber kit
DuVaL rAcEr
Suspension & Brakes
12
Feb 5, 2007 06:32 PM
Royal_C!ty
Sep 27, 2005 11:26 AM
LOC714
Jan 7, 2005 04:00 PM
goofyej6
18
May 27, 2004 05:06 PM
crex23
May 13, 2003 10:50 AM
