Ok, ASR 22mm DC2 complete kit instructions?
I'm generally not the person to need instructions, especially in regard to the function of the ASR complete kit, but my kit came with none, are they supposed to?
My Main question is, for the DC2/EG complete kit, the pieces that fit inside of the subframe with the bore outs, are you suppsoed to remove the welded tack nuts on the inside? Is that not what the bore outs are for these pieces? It fits right over...or is it even needed at all?
Those of you who got the DC2/EG complete 22m kits recently, did it come with the aurora endlinks and did you recieve bolts to connect the endlink to the LCA and the sway bar to the endlinks? I received the OE endlinks. Also did you get rubber sway bar bushings or the newer metal spacers; I got the rubber ones. I know got a genuine kit, just i think i got older stock of it and therefore an older hardware kit I've already contacted the place I bought from as well as Charleston from ASRParts to confirm, just awaiting replies.
Re: Ok, ASR 22mm DC2 complete kit instructions? (chrisw85)
Hello,
We will be uploading the instruction on our website soon. For the meantime
the instructions can be downloaded from Password JDM.
The EG/DC instructions are on this link
http://www.passwordjdm.com/Ins...G.pdf
The EK instructions are on this link
http://www.passwordjdm.com/Ins...K.pdf
Sorry for the inconvenience it may have cause.
Charleston
Charleston
Re: Ok, ASR 22mm DC2 complete kit instructions? (CivicFerio)
Thanks man, prompt replies! Great products and great service.
I already took a trip to my local OSH and bought some grade 10.9 M8x40 and M10x40 bolts for the endlinks. Now I just need to find my drill....
