Suspension & Brakes Theory, alignment, spring rates....
coilover question
Old Sep 17, 2006 | 07:59 PM
gsr1289's Avatar
Default coilover question
whats the difference between an inverted mono tube desgin and a non inverted mono tube design?
thanks in advance
Old Sep 18, 2006 | 07:11 PM
PIC Performance's Avatar
Default Re: coilover question (gsr1289)
An inverted design mounts the shock body to the upper mount, and the shaft connects to the lower mount. The non-inverted design is the other way around. Most OEM and aftermarket designs use non-inverted, although some use the inverted design, such as the STi's factory dampers.
An inverted design provides less unsprung weight and keeps the shock body further away from the heat generated by your brakes, allowing the oil inside to stay cooler. They are also supposed to be able to withstand higher lateral loads than a non-inverted design.
96hb
Suspension & Brakes
Mar 29, 2010 07:30 PM
skaternak
Jan 26, 2010 02:47 PM
SkyeC
May 25, 2005 08:33 PM
venomcivic
Aug 11, 2003 08:13 AM
sleepyhamsterlx
May 6, 2003 07:27 PM
