Quick DA/DC question.
If I swapped out the DC front forks for a pair of DA front forks, and ran DA coilovers on it, would that work?
In other words, I know the reason I cant run DA coilovers on my DC is because of different front fork diameters, but if I swapped out the front forks, would that work?
you car may have mad rake, DA rear suspension is about 3" longer than DC. If your coilovers are adjustable enough you may get it even but it will be high off the ground.
I have the opposite of what you have, I have a DA with DC suspension. Its great for slamming DA's
FRONTS: DA shocks with DA forks or DC/EG shocks with DC/EG forks
REARS: direct bolt on... DA shocks are longer than DC/EG... less suspension travel for a dropped DC/EG on DA shocks... more suspension travel for a dropped DA on DC/EG shocks
