Suspension & Brakes Theory, alignment, spring rates....
shock question
Old Sep 26, 2007 | 11:35 PM
kixcrx's Avatar
Default shock question
are those shocks from autozone any good
Old Sep 26, 2007 | 11:44 PM
bmoua's Avatar
might be good if your at stock height...
Old Sep 26, 2007 | 11:51 PM
kixcrx's Avatar
Default Re: (bmoua)
does being on coil over springs without the sleeves count
Old Sep 26, 2007 | 11:54 PM
bmoua's Avatar
Default Re: (kixcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kixcrx &raquo;</TD></TR><TR><TD CLASS="quote">does being on coil over springs without the sleeves count </TD></TR></TABLE>
you mean lowering springs....whats your budget? any stock replacement shock will suck. Unless you want to save the most amount of money, i'd just pick up used stock shocks and call it day. Just keep in mind you get what you pay for.
edit....your not running the actual coilover springs right????
Old Sep 26, 2007 | 11:58 PM
kixcrx's Avatar
Default Re: (bmoua)
yeah im riding on coil over springs cause my stock springs were cut and had them for a while till they messed up and they where cut all crooked and blew out my front shocks and the driver side rear one so i took off those springs and installed some coil over springs i had laying around couldnt find sleeves so just installed them like that
Old Sep 27, 2007 | 12:11 AM
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kixcrx &raquo;</TD></TR><TR><TD CLASS="quote">yeah im riding on coil over springs cause my stock springs were cut and had them for a while till they messed up and they where cut all crooked and blew out my front shocks and the driver side rear one so i took off those springs and installed some coil over springs i had laying around couldnt find sleeves so just installed them like that </TD></TR></TABLE>
first off you should not be running coilover springs on any car at all bro. They are too short and not meant for that kind of use.
whats your budget?
Old Sep 27, 2007 | 05:09 AM
gsrob's Avatar
Default Re: (bmoua)
Yeah that doesn't sound like a very good idea. You should probably look into getting some descent springs then too.
AutoDB8
Suspension & Brakes
Apr 13, 2009 02:08 PM
ricerodder91EX
Feb 19, 2008 05:42 PM
kixcrx
Oct 15, 2006 07:56 PM
romoracing
Dec 30, 2004 01:36 PM
integrx
Nov 18, 2003 07:18 AM
