Suspension & Brakes Theory, alignment, spring rates....
prothane motor mount inserts
Old Sep 24, 2007 | 01:18 PM
rudebwoy's Avatar
Default prothane motor mount inserts
has anyone used these inserts? what is ya'll experience with them. ride comfort reliability etc.
I got a set in the mail today, and they seems lke solid plastic mounts, no flex at all.
Modified by rudebwoy at 11:35 PM 9/24/2007
Old Sep 24, 2007 | 06:21 PM
suspendedHatch's Avatar
Default Re: prothane motor mount inserts (rudebwoy)
When I had the opportunity to compare Prothane to ES about 5 years ago, I liked the Prothane better (less squeaking and distortion). But that's probably not relevant now that ES offers the black graphite impregnated bushings.
Prothane has a very limited catalog compared to ES.
Old Sep 24, 2007 | 06:42 PM
excivicboy96's Avatar
Default Re: prothane motor mount inserts (suspendedHatch)
The prothanes are a lot stiffer than the ES ones. The ES seem more flexy. I just did all my inserts last week. Good upgrade.
Old Sep 25, 2007 | 02:22 AM
rudebwoy's Avatar
the parts provided with prothane seems a lot better than energy, I used enery before and tore them.
prothane actually replaces the factory rubber.
Old Sep 25, 2007 | 08:14 AM
cibola's Avatar
Default Re: (rudebwoy)
Before you install the inserts grease them up and that should prevent the squeek that you might get.
Your interior vibration will be increased if you do decide to install the rear mount. Be prepared to remove after a month or two, most do not like the inside of the car shaking so much.
Old Sep 25, 2007 | 12:06 PM
rudebwoy's Avatar
Default Re: (cibola)
I have the Avid lower torque mounts installed right now and its like driving a armored personnel carrier, I can't imagine what its gonna feel like with a complete solid motor mount kit.
Old Sep 25, 2007 | 11:26 PM
rudebwoy's Avatar
what if I glue them in using that 3M window weld silicone, would that be better than greasing them up?
CRXified
Dec 28, 2006 08:40 PM
AlienKrOZ
Jun 29, 2006 01:48 PM
integra3586
Aug 28, 2005 08:14 AM
TypeRuz
May 20, 2004 05:55 PM
inzaneN1
Feb 26, 2004 12:23 AM
