Suspension & Brakes Theory, alignment, spring rates....
Spring sizes?
Old Oct 9, 2007 | 11:52 PM
Emerica's Avatar
Default Spring sizes?
I do not know much about springs but I see that they come in different sizes such as 6", 7", 8", and so forth. Is there a benefit to having longer or shorter springs? Any helpful input is appreciated.
Old Oct 10, 2007 | 09:31 AM
PIC Performance's Avatar
Default Re: Spring sizes? (Emerica)
If all other factors remain the same, a shorter spring (fewer actve coils) will have a higher rate than a longer one.
Typically, shorter and longer springs of the same spring rate will have different wire diameters and/or coil diameters in order to keep the same rate.
Old Oct 10, 2007 | 10:36 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Of course the spring length also determines the maximum and minimum ride height you can go with your coilovers.
Old Oct 11, 2007 | 09:52 AM
Emerica's Avatar
Ah ha
Old Oct 11, 2007 | 10:52 AM
TunerN00b's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Of course the spring length also determines the maximum and minimum ride height you can go with your coilovers.</TD></TR></TABLE>
Additionally, too short of a spring will coil bind before you otherwise run out of suspension travel.
jdmhatch1
Suspension & Brakes
17
Feb 27, 2009 06:54 AM
dirrrtykorean
Suspension & Brakes
Sep 3, 2008 05:34 AM
bosco500
Suspension & Brakes
Jun 7, 2005 08:28 AM
u2civic1
May 5, 2004 03:52 AM
91SiKen
Mar 5, 2002 06:34 PM
