Suspension & Brakes Theory, alignment, spring rates....
soft brake problem
Old Jan 3, 2010 | 11:30 AM
jonepark's Avatar
New User
Default soft brake problem
Hi,
I own an 01 odyssey and I experienced the soft brake issue when I switch on my AC.I also have an 1993 civic and the same problem when the AC is switched on. why this is so happening guys,anyone know about this.Hope to get help from you.
Thanks.
Old Jan 3, 2010 | 04:17 PM
jr_deleon's Avatar
Default Re: soft brake problem
Hmmm. I like these interesting problems. Lets see...
I would think that it has something to do with vacuum assist from the booster (because the idle drops somewhat when the compressor clutch is switched on). My thoughts are jumbled after this long weekend so it might sound weird, but the only link between the A/C system and the brake system would be the vacuum created by the motor, and the change in vacuum associated with the A/C on and its effect on available booster vacuum. No power assist (no vacuum)= rock hard pedal Excessive vacuum conversely should mean a softer pedal. Does the idle rise when the pedal is depressed?
Just a thought. An out-of-the-box one at that
s13hero
Mar 27, 2010 04:16 PM
Cambocheen!
Mar 23, 2009 12:09 PM
slim9300
Jul 14, 2004 10:14 AM
slim9300
May 10, 2004 07:03 PM
