Suspension & Brakes Theory, alignment, spring rates....
function 7 control arms
Old Jan 7, 2010 | 08:57 PM
2000EJ8's Avatar
Default function 7 control arms
i have a 2000 civic EX with function 7 control arms.
I have a CTR 22 mm rear sway bar on the way
i have D2 coilovers with the standard spring rates(i believe this is 7k Front/5k rear, or either 9kfront/ 7k rear)
the LCA's come with 3 different mounting spots for endlinks. i guess they control how stiff or soft the sway bar is.....
i'm not sure as to which hole i should put the endlink through though. this is my first time adding a rear sway bar to any car.
Old Jan 7, 2010 | 09:31 PM
1.5Slowmatic's Avatar
Default Re: function 7 control arms
put the endlink in the middle hole of the 3 and call it a day
Old Jan 9, 2010 | 09:07 PM
CAM0FLAG3's Avatar
I don't know either. but i would say try them all... whatever feels best for you.
Old Jan 10, 2010 | 01:10 AM
bsmith100's Avatar
I would contact Function 7 and ask them which hole is closest to the stock position and set it there. Or go with the middle. I think that is what they recommend anyway. You might want to check with Function 7 since I'm not positive about that.
Old Feb 3, 2010 | 09:31 AM
Function7's Avatar
If you have our EK arms, there is a 4th hole (below the 3 holes on the top row) marked with an "O" -- that is the "stock" mounting location.
-A
boosteddb1_808
Aug 29, 2010 03:07 PM
08rampage
Jan 31, 2009 05:38 PM
bebeon_ek
67
Jul 7, 2005 09:53 PM
Tyson
Sep 26, 2003 04:26 PM
