Suspension compatibility question. Help please
Quick question:
Would the suspension (struts and springs) from a 93 sedan civic fit on a 96 civic hatch? is the suspension at all compatible?
Re: Suspension compatibility question. Help please
Yes the will.
On the front top hat there are 4 little things that stop it from sliding into the whole, wack them off with a dermil or something, i just used vice grips, and fillied it down a bit.
On the rear the lower shock forks are a little to wide for the 96 lca, you can either use washers or bend the shock fork a little bit.
ogawa_jiei
03-28-2004 02:36 PM
