Suspension & Brakes Theory, alignment, spring rates....
brake problem help!!
Old Apr 17, 2010 | 04:55 PM
jdmswappedcivic's Avatar
Default brake problem help!!
ok the car is a 91 si crx.. with an 11 inch fast brake kit.. its using integra calipers front and rear new stainless steel lines... car has great brake pressure when not running when running it goes right down to the floor .... i have bled the brakes many times swapped out the civic ex master cylinder and brake booster with a new type r 1 inch master cylinder and booster and still the same problem i orginally thought it would of been the booster but now on the second one with the same issue.. any thoughts??
Old Apr 18, 2010 | 03:25 PM
DROCK615's Avatar
Default Re: brake problem help!!
Have you checked the hard steel lines that run to the rear. They could be worn out.
Old Apr 18, 2010 | 09:30 PM
they look good.. no leaks anywhere.. the one thing i didnt do was bench bleed the master cylinder so going to try that and see where it goes
CarBug
Jun 12, 2016 01:51 PM
2nr808
Jun 6, 2012 10:55 AM
rockrig
Nov 21, 2011 02:01 AM
89crxsi89
17
Mar 17, 2010 10:35 PM
MrEg
Sep 22, 2003 04:49 PM
