Suspension & Brakes Theory, alignment, spring rates....
Function and form type 1 on efs
Old Jan 9, 2013 | 08:44 AM
alex1321's Avatar
Default Function and form type 1 on efs
Hi Im looking for a ''stance'' suspension I found at the function and form type one but I checked some posts and people say that the front doesnt wanna go in the fenders so, what should I look for? I will use 9.5 and 8.5 rims so i need it low
Old Jan 9, 2013 | 11:16 AM
EFnCRX's Avatar
Default Re: Function and form type 1 on efs
Stance is lame. Stay practical. But to answer your question the type 1s won't give you what you're looking for.
Old Jan 9, 2013 | 11:30 AM
F22Master's Avatar
Koni Yellows with extended top hats and either find some used lowering springs for cheap, or spend some dough and get the Ground Control sleeves/springs.
Koni Yellows with cheap lowering springs and Ebay extended top hats ~ $600?
Koni Yellows with Ground Control sleeves/springs/tophats ~ $1000
Old Jan 9, 2013 | 12:10 PM
mechanix619's Avatar
The best, and that's very relative, way to achieve what you desire is to install air suspension.
Old Jan 9, 2013 | 12:44 PM
4drEF's Avatar
Keyboard Humorist
Why not just fully stance out your car and simply cut the springs.
Very cost effective and gives you the same poor drivability issues that you would have if you spent money.
Old Jan 9, 2013 | 12:48 PM
alex1321's Avatar
Nah it wont I atm have cut springs and it sux badly hehe Ill need it stiff cause I wont want my wheels to reach fenders I just need some of your setups and photo if you have. Thx for the build F22 Lfm!
Old Jan 9, 2013 | 12:55 PM
alex1321's Avatar
I guess that kit is a good one but it seems like theres missing parts top plates.. http://www.ebay.com/itm/4525-01-Grou...ee3907&vxp=mtr
Old Jan 9, 2013 | 02:51 PM
F22Master's Avatar
http://www.ebay.com/itm/EF-EG-EK-DA-...ccdfed&vxp=mtr
Old Jan 9, 2013 | 02:52 PM
F22Master's Avatar
But you usually re-use the stock ones when replacing struts
Old Jan 9, 2013 | 04:13 PM
ghosthatch's Avatar
just the fact that you had to put quotes around stanced shows how much youre just following the fad. ***** wack
function and form makes a good product though
Old Jan 9, 2013 | 05:05 PM
alex1321's Avatar
Yo I wont pay 700 just to try it out Im checking peoples comments and they say that its not giving a nice reault at the front. So I can use oem top plate on koni yellow with ground control top plates?
Old Jan 10, 2013 | 12:51 AM
HFDSpace-Junk's Avatar
FF1s wont get it right. FF2s will. but the cost outweighs the gain.
"stance" is cool and evrything, but all it really gets you in the long run is a car with tires taht are bald on the inside and crappy handling.
koni yellow, cheap springs, and gc top hats are what you need if youre on a budget.
Old Jan 10, 2013 | 06:37 AM
alex1321's Avatar
Okok koni yellow arnt cheap hehe
Old Jan 10, 2013 | 10:11 AM
DCRB's Avatar
how do they hold up to some track abuse? like autocross, canyon runs, etc
Old Jan 10, 2013 | 10:56 AM
4drEF's Avatar
Keyboard Humorist
Stance thread.
No track use going on here.
Old Jan 10, 2013 | 11:32 AM
Captain Key!s's Avatar
Slamming an EF on a budget wont really happen. FF coilovers will not get the car low. Period. They will slam just about every other chassis, but not the 88-91 civic/crx. You need to look at Ground Control coilovers with custom spring rates (500 lbs+) for the front, shorter springs and set on the lowest perch of the Koni shock body and either Ground Control or custom upper mounts (top hats) to retain some shock travel. To fit the widths you are speaking of you will need at least a camber kit for the rear to go beyond the negative camber when you slam your car. Possibly even a front kit depending of the offset and how much you want to tuck. With the front kit, you greatly increase the chance of your UCA hitting the shock tower...now you need to cut holes in your towers. This is like black magic for EF's...you cannot just slap on coilovers and dump. Sorry.
Or you could just get ebay sleeves, oem struts and bounce on down the street.
Old Jan 10, 2013 | 02:07 PM
alex1321's Avatar
Hahaha yeah bouncing on ground is what I do atm Ill probly go for koni yellow struts and ground control coil and sleeve with oem top plates
Old Jan 10, 2013 | 07:35 PM
F22Master's Avatar
Good idea! At least you're listening lol
But i would suggest finding someone on here who modifies stock top hats. You are GOING TO NEED extended top hats if you dont want to continually bottom out your $500+ Koni's... Should be able to find a decent set of 4 for $50?
Old Jan 10, 2013 | 07:42 PM
alex1321's Avatar
Yeah Ill try to look at it I found 4 koni yellow wich were on an integra 2000 for 400 but I think theyre too long :S am I right?
Old Jan 10, 2013 | 08:01 PM
F22Master's Avatar
Looking at the model #'s:
One pair are the same, the other are different.
Whether its the front or the rear that are the same, idk.
But here is a full brand new set for $503 with free shipping.
http://www.tunersports.com/koni-spor...ort_p2154.html
Old Jan 11, 2013 | 06:07 AM
alex1321's Avatar
Awsomeeee thx for that link :D Ill mail them to know how much would cost the shipping to canada quebec since free shipping is only for lower 48 states
Old Jan 11, 2013 | 11:29 AM
Dude...order from THMotorsports.com Best Koni prices period.
Old Jan 11, 2013 | 12:04 PM
alex1321's Avatar
They sell a koni ground control combo right?
Old Jan 11, 2013 | 07:18 PM
F22Master's Avatar
THM = $530
Tunersports = $503
Both have free shipping. How is THM cheaper?
Old Jan 12, 2013 | 02:59 PM
b20vtec-CR-X's Avatar
koni yellows w/ gc coilovers and extended caps is your best bet
