Suspension & Brakes Theory, alignment, spring rates....
wheel bearing?
Old 03-22-2013, 04:20 PM
jdmsir4dr's Avatar
Default wheel bearing?
what could cause my wheel bearing to go bad on my ek? Its about 3 months old...its oem from honda
Old 03-23-2013, 01:08 AM
Tyson's Avatar
Default Re: wheel bearing?
bad installation.
Old 03-23-2013, 02:50 AM
B(eighteen)C's Avatar
Old 03-25-2013, 05:25 PM
1998GsRIntegra's Avatar
Ditto on improper installation. That's about it if the bearing is really only 3 months old and was a brand new oem honda part.
Old 04-04-2013, 08:34 AM
califas080's Avatar
Did you change the hubs along with your bearings? If you used your old one that might be it
Old 04-08-2013, 08:37 AM
jdmsir4dr's Avatar
I looked on advance auto parts and rockauto.com for the front hub and They only have rear hubs.. Its my front passenger bearing dats bad
Old 04-14-2013, 10:54 PM
9psiTURBOsi's Avatar
There could be many things that can go bad. Anywhere from defective to improper installation. I say stick with oem and you won't have a problem.
Old 04-19-2013, 03:24 PM
AZCRXSI's Avatar
Bad install I bet. Who did the install?
If its a shop, have them redo it. I just did mine myself, its not too difficult.
Old 04-20-2013, 01:39 AM
ATISTANG's Avatar
A lot of times people don't realize that the axle nut preloads the wheel bearing, this could be a case of over tightening, under tightening, or forgetting to dent the axle but and it has backed off
Old 04-22-2013, 04:48 AM
califas080's Avatar
You can get them New from this site: http://www.hondapartsunlimited.com/index.php?p=home
or Auto Fair Honda
I hope that helps but like the others said there could be a number of factors that could have contributed to the bearing going bad. Have someone professionally install them if you have next time.
Old 04-22-2013, 01:39 PM
jdmsir4dr's Avatar
I figuered it out .. the axel nut was stripped so it wasnt tight enough
Old 04-23-2013, 07:53 PM
Dead CIVIC's Avatar
Good to see this was solved.
avio
12-20-2010 08:16 AM
bsmith100
04-12-2010 08:05 AM
ketchup
03-10-2008 06:06 PM
jdmpnoy89
09-19-2007 01:45 AM
yung98gsr
02-18-2005 09:28 AM
Quick Reply: wheel bearing?
