Non abs disc to drum help
Hi i got some rear spindles with disc brakes want to convert my drums but didnt realize they had a abs sensor on them. I was wondering if anyone could explain what I need to do to remove the abs sensor. I think just need a non abs rear hub right? Or is there some other steps to this i have go through. Thanks my fellow honda community for the future reply's.
MM Gruppe B
Re: Non abs disc to drum help
trailing arms on 88-00 civic/ 90-01 integras are the same. so you can covert ether way just remove the 4 large t-50 trox on the back of the trailing arm and remove the hub and install your hub with disks with the respected e-brake cables done.. don't do anything with the ABS sensor i always remove it or cut the wiring on it and leave it behind so it doesn't matter
My bad for the mind **** I was rushing out the door. But what i was asking I have rear drums and just got some rear spindles with disc. Later when i got home i took a good look at them and noticed they abs sensor on them. So i wonder what i need to do to properly remove the abs sensor since my civic is a none abs.
b18ctrb
06-10-2008 04:28 AM
JDMCRX
05-28-2008 06:45 PM
