Suspension & Brakes Theory, alignment, spring rates....
coilovers
Old Mar 27, 2013 | 04:02 PM
francoreyes90's Avatar
Default coilovers
Hello everyone im hoping I can get some help here. Idk if this topic has been talkes about.
I bought some coilovers sleeves and skunk2 sport shocks. I would like some guidance on how to install them on a 99 honda civix ex. I have been looking up videos but they dont show any assemblies. Some say u need to preload the spring. PLZ HELP! THANKS
Old Mar 27, 2013 | 04:07 PM
grumblemarc's Avatar
The Grumpiest
Default Re: coilovers
You should try using the search feature. Someone just asked this just recently.
https://honda-tech.com/forums/suspension-brakes-54/coilover-sleeves-3133457/
Don't know where you're getting this preload thing from.
Old Mar 27, 2013 | 04:12 PM
During my search on youtube It shows a video of everything assembled and the person is compressing the spring to the top hat using the perch
Old Mar 27, 2013 | 07:03 PM
I know this is all simple but I ask bcuz my ride height didnt look like it change and when I installed them I had the spring all the way at the bottom
Old Mar 27, 2013 | 07:23 PM
tylerfromnj's Avatar
Buy a decent suspension set up.
Old Mar 27, 2013 | 09:50 PM
808zrk's Avatar
since you adjust the height with the spring perch instead of a threaded shock body your not gonna have preload if you go low. Preload is for full coilovers where the height is adjusted using the threaded shock body. And hopefully your coil sleeves are compatible with your shocks.. search gc/koni coilover install to get an idea of what your'e doing
Old Mar 28, 2013 | 03:50 AM
The Grumpiest
Has yet to say what coilover sleeves he is running. Ebay?
Old Mar 28, 2013 | 10:10 AM
they are from option racing coilover sleeves
Old Mar 28, 2013 | 10:12 AM
i know i went fairly cheap on the coilovers cuz i got them for 60 new id figure the height would actually sit flush the the tire or sit lower and cover an inch or so
Old Mar 28, 2013 | 10:13 AM
The Grumpiest
=Off brand generic "Ebay" sleeves.
Old Mar 28, 2013 | 10:25 AM
yea i guess they are close to didnt buy directly from ebay.
Old Mar 28, 2013 | 11:34 AM
The Grumpiest
So you have them installed ALREADY? Why didn't you just say so in the first post? If what you say is true then you OBVIOUSLY did something very wrong. Post detailed pictures.
Old Mar 28, 2013 | 03:03 PM
Ill post some later but I followed the procedure according to skunk2 demostration
Old Mar 28, 2013 | 03:11 PM
The Grumpiest
Then you shouldn't be having any issues then.
x1xofakindx
Suspension & Brakes
Mar 28, 2009 08:45 PM
jetpilot
Suspension & Brakes
13
Oct 24, 2006 08:48 PM
jbell
Suspension & Brakes
13
Sep 10, 2005 06:22 PM
BanEL
Nov 19, 2002 10:07 PM
buckfittyone
Aug 20, 2002 09:03 PM
