ground control help
i just purchased a set of used gc and the spring rates are 500 and 600, but the spring that are rated at 600 are like a inch shorter is that fine the numbers on the springs read 0600.250.0600 and 0800.250.0500, which would you put in the rear and which in the front TIA
If you mean using just the springs without the threaded sleeves, you can use them, but in that case they would be too short.
If you mean putting Ground Control threaded sleeves onto a Koni with a regular spring cup, I think something bad will happen.
GC has a specific sleeve made to fit onto a Koni-shock, but I dont know if there is an adapter for other GC sleeves to fit onto Konis.
i meant putting the gc threaded sleeves on to the regular spring cup cuz i currently got no job and paying for school is cutting into my saving account like crazy, but school is priority
if you do what you just discribed EXPECT to have a suspension falure. And Koni nor GC will cover it, becuse the producst were installed incorrectly.
If you search around some one thought of doin what you did with another coilover, and well as expected the mount failed.
The C-clip is not designed to work how you want to put it together.
MrOsvaldo221
Suspension & Brakes
Nov 29, 2013 12:51 AM
Showoff
Apr 1, 2003 08:45 PM
spd18
Mar 13, 2003 06:56 PM
thinkbrianthink bu
Jul 22, 2002 08:08 AM
