Suspension & Brakes Theory, alignment, spring rates....
Shocks
Old Dec 22, 2005 | 09:49 PM
AZNracerx1989's Avatar
Default Shocks
I saw on the other thread that Tokico blues will blow if u drop your car lower than 1.8 inches... is that true?
if thats the case.. im assuming kyb gr2's wont handle any more than 1.8 either?
how much do I have to spend to buy one that doesnt blow
Old Dec 22, 2005 | 09:59 PM
PIC Performance's Avatar
Default Re: Shocks (AZNracerx1989)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">how much do I have to spend to buy one that doesnt blow</TD></TR></TABLE>
Same amount that you'd spend on one that does. Meaning, any coilover can blow or not blow, it depends on how good you are at following directions and using common sense.
Old Dec 23, 2005 | 04:26 AM
PrinceAli132's Avatar
Default Re: Shocks (PIC Performance)
Look into koni yellow, they will handle 1.8" without a problem. They go for around 500 though.
Ali
Old Dec 23, 2005 | 09:29 AM
ITC Racer's Avatar
Default Re: Shocks (PrinceAli132)
Most OEM replacement struts/shocks are not designed to be installed on cars that are dropped that much- probably more than an inch or so. There are people that run them like that and may or may not have problems- it depends on how you drive the car and the roads you run.
If you must run that low, you can have Koni shorten the shocks to retain some suspension travel before the shock/strut bottoms out and blows.
Old Dec 23, 2005 | 03:29 PM
will KYB AGX handle up to about 2in drop?
Old Dec 23, 2005 | 10:42 PM
Sequoyah's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AZNracerx1989 &raquo;</TD></TR><TR><TD CLASS="quote">will KYB AGX handle up to about 2in drop?</TD></TR></TABLE>
It says what they'll cover...this is the main reason I'm going w/ Koni as opposed to other companies.
KYB America LLC warrants the listed quality-built products for the listed time period and/or mileage to the original retail purchaser against defect and wear-out when used on private passenger cars and light trucks under normal operating conditions. The warranty does not apply to shock absorbers which have been modified, improperly applied or installed, or installed on vehicles used in racing or for commercial applications. The warranty is void if the product is used on excessively lowered (over 1.5") vehicles or in an aftermarket coilover suspension system.
KYB's obligation under this warranty is limited to replacement of the defective shock absorber in accordance with this warranty. Cost of removal and installation are not included.
This is one of the main reasons I am going to buy Koni's. Most other companies have similar warranties to KYB
98GSRDC2
Suspension & Brakes
Aug 13, 2007 11:55 AM
PatrickGSR94
Suspension & Brakes
19
Apr 26, 2007 09:30 AM
bigBOI_92DA9
Aug 31, 2005 06:30 AM
sleepin91teg
Feb 5, 2004 06:32 AM
ACR
Apr 25, 2003 01:41 AM
