how the hell did this happen?
agx-shocks h&r-springs
took my coilovers off and put my springs back on, pulled out of my driveway and went down the street started hearing a clunking noise so i pulled over and the rear passanger side shock tower shot through the top hat and is sitting like a couple of inches above the top hat? i have had a blown shock b4 but how did this one do this?
Re: how the hell did this happen? (sackNsave)
you forgot the funny shaped washer under the dust cover. or it got misplaced and came off the shock rod when/if you tried adjusting it and hiding inside the dust cover.
#5 PLATE, BUMP STOP
install it correctly. everything should be fine.
(i swear i need to take a better picture of this...)
#5 PLATE, BUMP STOP
Re: how the hell did this happen? (Tyson)
so the shock is not blown/messed up? just need to re-install?
i think i installed it but im not 100% sure if that piece is installed what could it be?
you should if you can (regular springs you can, they dont fit with any threaded sleeves). but you dont absolutely need to. theres no reason not to either.
went to honda and they dont stock the washer so gotta wait till like wed. found a pretty looking washer is that ok to use or just wait? what specisfacation does the washer must have? its smaller and thinner than the oem ones.
#1 Super Guy
The one your missing is a fat steel plate with a tappered seat that matches the tapered seat on the shock shaft perfectly. If you use a different type of washer with an OEM shock, it can easily bust it's way through and ruin the shock shaft...
b16_madman
07-26-2003 01:10 PM
