Suspension & Brakes Theory, alignment, spring rates....
toe arm?
Old Jul 19, 2006 | 08:54 PM
91highryda's Avatar
Default toe arm?
have a 92 civic vx..im doing a rear disc conversion on it and i have a ? bout it cant kind an anwer anywere.......the bolt that goes to the frame(not the one on trailing arm the other side of the toe arm or bar) have the bushing stuck to it and on the other side there i suppost to be a nut on the other side right?cant get the bolt out bu of bushin amd we cant get the bolt back in the whole and it just turns thats really bad right lol i know its a stupid ? but any one have any idea if it can be fix ?......thanks alot brandon
Old Jul 20, 2006 | 05:06 PM
PIC Performance's Avatar
Default Re: toe arm? (91highryda)
If I am picturing it correctly, there might be one way. I forgot the name of it... but there is a tool out there (a drill bit more or less) that you use to drill down the center of the bolt, and then you just throw the drill in reverse and it will pull the bolt out.
Do you have some pictures to detail the problem?
Old Jul 20, 2006 | 05:21 PM
Tyson's Avatar
you should NOT have even tried to take that bolt out. you didnt even have to loosen that bolt, unless you were attempting to realign your toe. youre supposed to use the same toe arm so you didnt have to take that off anyway.
anyway, now that you messed that up, from what i hear, you could be screwed. theres a floating nut inside of there. if you cant locate the nut, then it fell off the tracks. if it fell out, then you have no option than to drill a big door **** sized hole in the back of your car right above that area to get to the nut.
Old Jul 20, 2006 | 11:08 PM
91highryda's Avatar
Default Re: toe arm? (Tyson)
no i dont have any pics im just thinkin of drillin a hole on there and........the one bolt on the trailing arm was rounded so bad that we couldnt get it off with the stip bolt kit we had we had to grind it off it suxs
thekidsnitty
Suspension & Brakes
Jul 2, 2012 05:57 PM
Eg253
Suspension & Brakes
30
Jun 24, 2006 05:10 AM
OneDirection
Suspension & Brakes
13
Jan 17, 2005 07:19 AM
Matt B
Apr 20, 2003 07:12 PM
