Suspension & Brakes Theory, alignment, spring rates....
Help... with height
Old Jul 18, 2006 | 09:27 AM
Thepanda's Avatar
Default Help... with height
I need someones help to try and figure out how far the tein springs will drop my car. Can anyone give me 4 measurements of the stock integra 94-01 style. I need the measure from the front and back wheel (center of wheel to the fender). I also need the height of the car from the side skirt right next to the front tire and right next to the back tire.
Here are the points that i need (this is my car it is already lowered.)
thank you for your help it is much appericated.
Modified by Thepanda at 10:39 AM 7/18/2006
Old Jul 19, 2006 | 08:45 AM
Thepanda's Avatar
Default Re: Help... with height (Thepanda)
bump
Old Jul 19, 2006 | 09:00 AM
__oversea's Avatar
it drops pretty much like that.
Old Jul 19, 2006 | 10:51 AM
Thepanda's Avatar
Default Re: Help... with height (Seungho711)
I still need the height of stock car....
thanks
Old Jul 19, 2006 | 04:53 PM
stumpyf4's Avatar
Easier to measure from the ground to the lip of the fender instead of the the centre of the wheel. Wheel size will make a difference as well.
My car as neither stock suspension or stock wheels, go to a dealer and measure a couple on the lot.
Old Jul 19, 2006 | 06:11 PM
chrisw85's Avatar
from teh rear jack point (not the side skirts) the stock heught is 7-1/4" to 6-1/2" depending on the model.
from the front jack point: 6-3/4" to 6" depending on the model.
those are the measurments to the best of my knowledge. i will remeasure later on to double check.
Old Jul 20, 2006 | 11:06 AM
Thepanda's Avatar
Default Re: (chrisw85)
thank you. I just need my car raised up a little bit it is way to lower.
nightshift
Honda Fit
Jul 25, 2006 06:45 AM
drtacura
Jun 16, 2005 11:55 AM
Project_ED8
Mar 18, 2004 08:00 PM
Quick Silver
Apr 7, 2003 08:04 PM
