Suspension & Brakes Theory, alignment, spring rates....
coilover question
Old Feb 27, 2007 | 07:40 PM
aaron590's Avatar
Default coilover question
I installed my front coilovers today and found out the adjusting ring on the passengers side coilover doesn't tighten all the way and can be turned when there is no pressure on it but can't be turned when car is on the ground. Do you think it will still be driveable until I can at least replace the ring?
Old Feb 27, 2007 | 10:44 PM
BlueIntegraBoy's Avatar
Default Re: coilover question (aaron590)
Doesn't it have two spring perches to lock each other?
Old Feb 28, 2007 | 05:54 PM
aaron590's Avatar
Default Re: coilover question (BlueIntegraBoy)
ok well I fixed the problem. The allen screw was too long so I just filed down the end of it and sure enough it fit.
EJ1_CRIS_909
Suspension & Brakes
12
Aug 23, 2011 10:09 AM
datssoled
Suspension & Brakes
Jun 27, 2007 07:25 AM
d16y8EL
Jun 26, 2004 12:31 AM
aznfab
Oct 22, 2003 12:39 PM
