Suspension & Brakes Theory, alignment, spring rates....
Bushing Question
Old May 6, 2007 | 02:59 PM
9200RPM's Avatar
Default Bushing Question
I have a 92 Si with a 5 lug conversion on it. I need to replace the bushings, and would like something stiffer than the OEM bushings. I looked in energy suspensions catalog and they don't have a kit for a Type-R. Is the only difference in the regular integra suspension and Type-R the 2 piece LCA. If so can I use a kit for a 99 SI. Thanks for any insite.
Old May 6, 2007 | 04:16 PM
BlueIntegraBoy's Avatar
Default Re: Bushing Question (TurboB16aEG)
You aren't going to have bushings on your 5-lug conversion, meaning if you just swapped over just the knuckles and trailing arms (which only contain the trailing arm bushings), then buy bushings for a 92-95 Civic.
Old May 6, 2007 | 06:09 PM
9200RPM's Avatar
Default Re: Bushing Question (BlueIntegraBoy)
Ok thanks
Greg456
Suspension & Brakes
Nov 20, 2007 04:20 AM
SE7EN3S
Sep 16, 2005 09:57 AM
SE7EN3S
Suspension & Brakes
Sep 16, 2005 09:41 AM
EricUSC
Mar 10, 2003 01:43 PM
mitchb
Mar 6, 2003 02:38 AM
