Suspension & Brakes Theory, alignment, spring rates....
having problems with tien's
Old May 22, 2007 | 05:13 PM
Car Tweaker's Avatar
Default having problems with tien's
i have a 92 hatch with tien master driving HA coilovers there for dc2's but thats not why im having this problem anyways im trying to get the car even all around by measuring from the bottom of the frame to the floor but on my back right coilover there is no more adjustment to raise the car down, i ran out of threads to adjust, when on my other back coilover i can go down and up about 3 more inches it sites perfect right in the middle of the threads, its even all around now but like i said im on the last thread on my back right side and im guessing this is going to cause the car to not handle well at all, does ANYONE know why i have no more room to lower the car ? also im using 15's with 205/50 and the wheel isnt even tucked under the fender or anything
thx in advanced dan
Old May 22, 2007 | 05:36 PM
anyone this issue is really making me think
Old May 22, 2007 | 06:00 PM
BUMPPPP
Old May 23, 2007 | 12:21 PM
turbo1.5's Avatar
My EF does the same thing with Tanabe Sustec Pro coilovers, but my car handles fine. I think my unibody is bent! Later I figured out that even though a tire is classed as being 195/60R14 the actual diameter of the tire is different between brands. For instance I have some old Pirelli P8000 tires (195/60R14) on the passsanger side and Falken ZIEX tires on the driver side. Suprisingly the Falken tire is almost half an inch larger in diameter! I measure from the middle of the fender well to to the ground and the passanger side is half an inch higher than the driver side to make it even. Just my .02 cents....
Old May 23, 2007 | 08:13 PM
USDM_R's Avatar
Default Re: (turbo1.5)
I would look at the threads on all of the coilovers and measure where they are sitting on the shocks----to check and see if the threads somehow got missaligned???? Hope this helps
Old May 24, 2007 | 08:58 AM
i think what i have to do it what they call preload...? bcuz the other coilover on the back the one that i dont have problems with i took that off and cleaned the threads so i can asjust it but before i put it back on it was sitting right in the middle and it sat perfectly i only had to adjust it a little bit
OregonDucks
Suspension & Brakes
26
Sep 27, 2015 08:18 AM
hardrock2401
Suspension & Brakes
Oct 14, 2014 12:50 PM
pr0gre551ve
Suspension & Brakes
May 17, 2014 02:03 PM
littlegreenb18
Oct 12, 2005 08:36 PM
Krnbk2
22
Apr 21, 2003 11:06 AM
