Suspension & Brakes Theory, alignment, spring rates....
ef6 crx gc/ eibach spring rates
Old Mar 11, 2008 | 10:47 AM
beecee's Avatar
Default ef6 crx gc/ eibach spring rates
im looking to buy gc koni yellow and eibach spring combo , what would you recommend for the spring rates , car is a daily driver , dont mind it being a little hard if its worth it , cheers Brian
PS if i just get the konis and springs , will same rates apply .
Old Mar 11, 2008 | 11:02 AM
Tyson's Avatar
Default Re: ef6 crx gc/ eibach spring rates (beecee)
the standard 350/250 spring rates GC gives fro the EF is fine for daily. it will be firmer than stock and as stiff as any aftermarket spring kit available.
when you want to change spring rates, you can buy a new pair or trade with others.
Old Mar 11, 2008 | 11:36 AM
beecee's Avatar
Default Re: ef6 crx gc/ eibach spring rates (Tyson)
considering the car wont be used for track days etc . are coilovers overkill ,
Old Mar 11, 2008 | 11:39 AM
Tyson's Avatar
no, not necessarily.
but i do think youll enjoy any aftermarket spring kit just as much. personally, i like eibach pro kits. theres a myraid number of spring kits at different ride heights and spring rates. it might a bit trial and error tho. so do your best to research.
GC kit allows adjustment of height and switching of springs for different spring rates. it is a bit overkill, but its useful to some who really want to get the exact ride hieght they want, and exact spring rates. the only benefit of a regular spring kit is that the rears are typically progressive which makes for a more comfortable ride. GC springs are only linear spring rates.
just know that everytime you change the ride height, you change the toe alignment. which affects tire wear and handling performance. so you need to realign the car everytime you adjust ride height.
Old Mar 11, 2008 | 11:53 AM
beecee's Avatar
ok , bear with me please , if i decide no to get the gc , would koni yellows and a progressive eibach spring be the way to go . thanks for the help .
Old Mar 11, 2008 | 11:56 AM
Tyson's Avatar
it would be fine.
but... for the money, i think tokico illuminas and eibach prokits make a better value and perform great. that was my first setup on my crx and loved it.
Old Mar 11, 2008 | 11:58 AM
beecee's Avatar
again many thanks for your input .
patrickstar
Suspension & Brakes
Feb 17, 2009 11:49 PM
DA is best
Suspension & Brakes
Jul 7, 2007 11:15 PM
pjr710
Suspension & Brakes
19
Apr 19, 2007 02:44 PM
01nhbgsr
Feb 23, 2004 03:47 PM
