Suspension & Brakes Theory, alignment, spring rates....
function form type 1 adjusting question
Old Jun 29, 2008 | 11:57 AM
jdm2envy's Avatar
Default function form type 1 fullcoilovers adjusting question
how can i adjust the ride height? do i need to adjust the top coil/ring (the one that spring sits on) or just the bottom collar (the part that bolts to the rear lower control arm or the piece that goes into the shock fork in the front). i wanna dumped my car thnks..
Old Jun 30, 2008 | 10:08 AM
f2autolife2's Avatar
In order to lower your car you must unlock the locking collar to the bottom mount, you must turm the lower mount up in order for your car to lower.
Old Jul 1, 2008 | 06:38 AM
evosix's Avatar
Default Re: (f2autolife2)
yes, you leave the top two collars alone, unlock the bottom color to the desired lowering point and then grab the whole assembly by the spring and turn it with your hands so it threads into the lower mount. To raise the car up unlock the lower collar again and grab the assembly and turn the other way so it comes out of the lower mount.
Old Jul 1, 2008 | 09:05 AM
pworld2's Avatar
Default Re: (evosix)
evosix explained how to do it without removing the suspension from the car. Just make sure the 2 perches under the spring are tight, and it basically will lock the spring to the shock assembly, so everything rotates inside the lower mount. thus lowering it or raising it
Old Jul 3, 2008 | 05:56 AM
jdm2envy's Avatar
nice! this helps me alot... ill try this later.....thanks evosix & pworld....
Old Jul 4, 2008 | 01:03 AM
stain's Avatar
Default Re: (jdm2envy)
;the f2 are the tight ***** yo how much are they
CubbyChowder
May 6, 2010 01:50 PM
Dubs13
Suspension & Brakes
Jul 1, 2008 09:44 AM
kaluwa3
Suspension & Brakes
May 13, 2007 03:39 PM
2BFI
Suspension & Brakes
Jul 2, 2006 07:34 AM
yh23
Suspension & Brakes
64
Jun 11, 2005 08:41 PM
