Suspension & Brakes Theory, alignment, spring rates....
CAR SHACKING... need input.......
Old Aug 25, 2008 | 09:23 AM
bias's Avatar
Default CAR SHAKING... need input.......
i recently changed my friends front shocks on his legend.. and now the car shakes from side to side... like the car needs an alignment... could this be problem?
cuz ive checked over everything twice to make sure it was bolted up and nothing else was done to the car
the car has about 170k.. so its pretty old
shakes around 30 mph
Old Aug 27, 2008 | 10:50 PM
mattison187's Avatar
Default Re: CAR SHAKING... need input....... (bias)
mabey the wheels arent balanced? thats what it sounds like 2 me. just my $.02
Old Aug 28, 2008 | 02:47 AM
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bias &raquo;</TD></TR><TR><TD CLASS="quote">i recently changed my friends front shocks on his legend.. and now the car shakes from side to side... like the car needs an alignment... could this be problem?
shakes around 30 mph</TD></TR></TABLE>
i'd go back and tighten all the bolts that you guys loosened to install the shocks.
From my experience, if your tires needs balancing, you'll only feel the shaking agove 50mph+. Worst comes to worst a alignment could be the problem.
Old Aug 28, 2008 | 10:14 AM
BLACKLIST138's Avatar
Default Re: CAR SHAKING... need input....... (bmoua)
legends and early body tl's are prone to axle bending issues
Replacing the axles will eliminate the low speed wabble.
First, Make sure you have the wheels balanced and installed correctly.
If its something that has began since you did the work, i guess you shade tree'd something and fouled it up along the way.
Good luck.
Old Aug 28, 2008 | 12:47 PM
bias's Avatar
Default Re: CAR SHAKING... need input....... (BLACKLIST138)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACKLIST138 &raquo;</TD></TR><TR><TD CLASS="quote">legends and early body tl's are prone to axle bending issues
Good luck. </TD></TR></TABLE>
yeah, the shaking accrued AFTER I replaced the shocks... which is weird because ive done TONS of suspension work on other cars.. and this is the first.
and EVERYTHING was looked over and tightened to make sure nothing was loose.
if his car was out of balance/ out of alignment from before... I figured he would feel it shake more now.. since the shocks are brand new?
ill take a look at his axles.. thanks for the heads up
bias
Acura TL, RL & ZDX
Aug 27, 2008 07:33 AM
recon23
Nov 19, 2007 09:11 AM
EG2Driver
Suspension & Brakes
May 26, 2006 12:40 PM
im done
Suspension & Brakes
May 9, 2005 01:13 AM
performula
10
Sep 18, 2002 04:22 PM
