Need Help with Rear Camber
Ok so im new to this camber method haha. Well I have positive camber in the rear and cant slam my car since it rubs. Im wondering if theres anyway I can fix it without buying a aftermarket camber kit. Well lmk thanks If theres a thread like this and answers on it plz lmk as well
Re: Need Help with Rear Camber
If this is the 98 Civic listed in the OP's sig, and he's using aftermarket (or stock) 92-95 Civic LCA's, then yeah that'll make for some nasty positive camber.
What he said
I'll try to snap a few pics but its raining , So my guess is I'll have to buy Aftermarket LCA Right or wrong ?
You need to figure out why you have positive camber in the first place. A car shouldn't ever have positive camber, even on stock suspension.
so you have aftermarket LCA?
if its not Skunk2, but SPC instead, then that would explain the positive camber as they are purposely set in. which is why i never recommend that brand specifically.
The car before had aftermarket lower control arms Skunk 2 from what the previous owner stated n he put stock ones and bam positive camber problem
The only way the camber could be positive after switching LCA's is if the current LCA's are shorter than the ones that were on there previously.
Maybe the previous owner did the camber trick. Where you add washers to the rear UCA to loose excessive negative camber. Check if there is any washers or anything fishy with the rear UCA
Either the upper arm is pushed out (washer trick like mentioned above) or you're using the incorrect lower arms (shorter than the stock 96-00 arms).
If none of the above, then something has to be bent/damaged, although I don't see that happening equally on both sides. Take some pics of the control arms underneath the rear of the car if you can.
EJK20R
Suspension & Brakes
03-19-2006 10:26 PM
