Suspension & Brakes Theory, alignment, spring rates....
Spring help
Old Mar 31, 2009 | 10:31 AM
Duc_du's Avatar
Default Spring help
I have ground control coilover for my 2000 civic si but the springs got cut. so im planning to buy H&R sport spring but i was wondering can i adjust how low i want to drop it? i just want a inch drop for now until have the money for new strut and camber kit. Or do i have to drop 1.75 as the product listed?
Old Mar 31, 2009 | 07:58 PM
uberJDM's Avatar
Default Re: Spring help
H&R sport springs are just lowering springs, you can't adjust the height. it will drop 1.75 in the front, 1.5 in the rear.
Old Mar 31, 2009 | 08:05 PM
mugen si's Avatar
you dont need a camber kit. just get an alignment and your set.
Old Mar 31, 2009 | 08:36 PM
Duc_du's Avatar
thanks uber for clearing that up.
i dont know i read a lot of forum and they all recommended camber kit if lower than 1.25. some said the same thing like you did but i just want to be safe. thanks aniway
Old Apr 3, 2009 | 02:19 PM
nonsense's Avatar
what do you meant the spring got cut? Why don't you but new springs from GC, they're pretty cheap
Old Apr 3, 2009 | 02:27 PM
revn99teg's Avatar
Thats not true. Having some negative camber is actaully a good thing for lowered cars because it helps tuck the tires so it won't hit the fender. This has been said many times, TOE is what kills your tires not camber. You only need to get a camber kit if you plan on lowering more than 2" because by then, your camber could reach up to -2.5 to -3 degrees, in which you will need to adjust your camber a bit to prevent only one side of your tire to wear. The sports only offer about a 1.75" drop in the front so you won't need it.
Old Apr 3, 2009 | 10:56 PM
Duc_du's Avatar
I end up buying Eibach prokit. going to save up for full coilover next year. but yeah thanks for all the feed back.
Old Apr 4, 2009 | 05:25 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Those other forums would be wrong.
You're not trying to use H&R Sport springs with the GC sleeves and perches are you? Just wanting to clear that up, because that most definitely would not work.
xsxnosxsx
Honda Civic (2006 - 2015)
10
Mar 24, 2011 06:21 AM
93civiccoupe
Suspension & Brakes
Jan 30, 2006 10:43 PM
RacerBoy
Sep 25, 2002 10:39 AM
Fooman
Sep 15, 2002 11:34 AM
vti-R
Oct 15, 2001 03:32 PM
