Suspension & Brakes Theory, alignment, spring rates....
Delete please
Old Apr 16, 2009 | 08:59 AM
95cx's Avatar
Default Delete please
Fixed
Old Apr 16, 2009 | 09:06 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Help me correct my alignment on 93 hatch
Ouch man, that's pretty bad. You need to get that right rear fixed up ASAP.
It's also odd that you had toe out on the left side, but toe in on the right side, unless the steering rack was not centered before they started? If not, then on whoever did that alignment.
At this point, your car is going to "crab walk" as you try to drive straight, which can cause tire wear issues all around.
Also, you do not need a camber kit. Besides tire wear from the bad rear thrust angle, you should not have any other tire wear issues up front with those toe settings.
Old Apr 16, 2009 | 09:53 AM
95cx's Avatar
Yea I'm waiting for a friend to bring me home a trailing arm so I can get that right rear squared away.
And I can kind of feel the crab walk while driving and the steering wheel "feel" is really crappy and occasionally a little tougher to turn, but I presume that is from caster being off?
As far as steering rack being centered, I'm sure if probably wasn't centered becasue my brother(Chevy world class technician) and I did this but we rushed through it just to get some rough numbers and see what's up. He works on Chevy's so the Honda world is like him doing carpentry work, and the Honda's have no adjustments anywhere except for toe.
Old Apr 16, 2009 | 09:55 AM
Community Builder
waiiit a second, I just noticed the negative caster, which means the knuckle is tilting forwards when it should be tilted backwards slightly towards the rear of the car. That is bad news and can make a car handle pretty poorly. How did it get like that? Do the wheels appear pushed backwards in the wheel arch at all? Has the car been wrecked?
Old Apr 16, 2009 | 10:37 AM
95cx's Avatar
I know that the drivers side appears to be pushed back but not sure about the passenger side.
The car was in a slight little dinger which was on the passenger side front that called for a new fender and hood. But, I don't think it was enough of a impact to mess up the structural integrity of the passenger side shock tower, but I could be wrong on the strength of a Honda.
Old Apr 17, 2009 | 03:52 AM
95cx's Avatar
Anyone else got any pointers as to what I can do to get the caster issue cured??
Old Apr 17, 2009 | 08:30 AM
95cx's Avatar
no help....
Old Apr 17, 2009 | 09:21 AM
94eg!'s Avatar
#1 Super Guy
Loved
Dood your caster is hosed. Either both lower control arms are pushed way backwards (likely), or the upper control arms are somehow pushed forward (unlikely). You are gonna want to go get the frame checked for straightness at a body repair facility. The forward LCA mounting points are part a large subframe that may be bent as well. Unfortunately the rear LCA mounting point is directly fixed to the chassis. If the chassis itself is damaged, it will be up to the frame shop to decide weather or not the car is fixable...
Is it possible someone else drove your car without you around?...
VTECROAR96typeR
Suspension & Brakes
Apr 4, 2010 10:11 AM
TurboEM1
Aug 28, 2006 11:30 AM
ccivic
Suspension & Brakes
Jan 31, 2005 11:28 AM
MrIllegalX
Oct 18, 2003 11:45 AM
rody084
Apr 16, 2003 01:30 PM
