Suspension & Brakes Theory, alignment, spring rates....
ebay extended top hats on koni/springs?
Old 08-16-2010, 01:57 PM
emooheo's Avatar
Default ebay extended top hats on koni/springs?
Do ebay extended top hats fit koni yellows?
Do the extended top hats work with lowering springs? i have only seen them on coilovers. I have stechs.
Old 08-16-2010, 05:42 PM
Master Detailer
98civdx's Avatar
Default Re: ebay extended top hats on koni/springs?
You can use extended top hats on springs if you would like, lots of people chose to do so when lowered over 2 inches.
Wether or not ebay ones will fit I dont know.
i saw on weaksauce koni is 12mm and stock is 10mm.
Old 09-01-2010, 01:31 AM
colgateam's Avatar
I'd like to know if those ebay ones would fit koni yellows too.
Bump
Old 09-01-2010, 04:17 PM
GSRCRXsi's Avatar
they should fit fine if you swap out the sleeves to the 12mm sleeves that konis need (the konis come with them)
Old 09-02-2010, 01:27 AM
kristo's Avatar
The question is not whether those will fit, but whether they will hold
dragonfly2k3
07-18-2008 12:31 PM
Psychochik
Honda Civic (2001 - 2005)
19
03-15-2008 11:02 PM
Jhonny Ricer
Suspension & Brakes
03-29-2007 03:27 AM
iLLA
12-20-2005 01:30 PM
Boostless97Lude
08-06-2003 01:25 PM
Quick Reply: ebay extended top hats on koni/springs?
