Suspension & Brakes Theory, alignment, spring rates....
Brake Cable StopTech
Old Nov 27, 2005 | 10:34 AM
WVTURBOCRX's Avatar
Default Brake Cable StopTech
Application:89' CRX SI with rear brake swap. The Calipers & Trailing arm are from 91 Teg.
I purchased StopTech Stainless Steel Brake Lines. Mfg Part Number: 85-054-5500(R), for the rear only from buybrakes.com; However look at the photo, the end does not fit onto the rear calipers, the metal flange is way to short and shaped wrong
My question... Has anyone else had this problem with these same lines?
Also what lines are you using that went on without a hitch?
[IMG][/IMG]
Old Nov 27, 2005 | 10:56 AM
snowman0520's Avatar
u tried fliping it around (upsidedown)? it a banjo fitting right?
Old Nov 27, 2005 | 12:43 PM
WVTURBOCRX's Avatar
Default Re: (snowman0520)
Yea, tried that. The rear brake is on the back side and would stick out toward the back and would not be long enough. Also it does not go the way.
Drop_A_Dookie
Suspension & Brakes
Dec 8, 2010 12:35 PM
Nisif
Jun 6, 2008 07:43 PM
CRX 2.0V-T
Oct 10, 2006 07:25 AM
WVTURBOCRX
Nov 27, 2005 06:29 PM
Vinceg99
Nov 21, 2002 05:42 AM
