do shocks squeak when they are blown...? need big help!!!
cause my rear passenger side is squeaking up a storm. if you move the car even a lil bit its squeaking like crazy. its so annoying. if its not the shocks what else can it be. could it be a loose bolt? my LCA bolt connecting the shock to the arm broke once and was replaced could it be that? bushing? need help!!!
#1 Super Guy
Re: do shocks squeak when they are blown...? need big help!!! (Manolo)
Usually squeeking is from worn bushings. If your car has been lowered, then I would guess the culprit is the main trailing arm bushing. These are forced into a twist at all times when civics/tegs/del sols are lowered. This causes them to wear out prematurly. If you do end up having to replace them, I suggest getting the new ones clocked the proper about to relieve the twist once the car is on the ground. Then you should enjoy tens of thousands of miles of squeek free operation...
Re: do shocks squeak when they are blown...? need big help!!! (apm)
I have tokico illumina.....rear passenger side is blown and when I shake it hard it squeaks so your shocks can be blow. take off your wheel and check to see if there is a lot of oil on your shock.
Ignitecivic
05-31-2002 07:54 AM
