Suspension & Brakes Theory, alignment, spring rates....
Is this a standard ground control eibach spring?
Old Mar 12, 2006 | 05:35 PM
EK k kay's Avatar
Default Is this a standard ground control eibach spring?
The fronts say 230.64.55 and the rears say 180.64.44. The rears look fine, but when I see most other ground control eibach springs they have 200.xx.xx instead of these. Is there any difference between 230 and 200?
Old Mar 12, 2006 | 06:03 PM
Tyson's Avatar
Default Re: Is this a standard ground control eibach spring? (EK k kay)
How do I tell what my spring rates are?
Ground Control sells Eibach Race Springs (ERS) which are labelled by 3 different values in the following convention: length . diameter . spring rate. However, ERS will come labelled in either Metric (mm.mm.N/m) or English (inchx100.inchx100.lbs/inch) units. 180.64.61 is the same thing as 700.250.350. The conversion from Metric to English is (/.254, /.254, x5.7) "/" means "divide by", "x" means "multiply by".
Old Mar 12, 2006 | 06:10 PM
EK k kay's Avatar
Default Re: Is this a standard ground control eibach spring? (Tyson)
I know the conversion. The question is are the fronts ots springs for an integra being 9" and having a spring rate of 315?
Old Mar 12, 2006 | 06:13 PM
Tyson's Avatar
no. its usually 8" 380lbs.
using a 9" spring is doable, but limits you on how low you can go.
Old Mar 12, 2006 | 06:25 PM
EK k kay's Avatar
They will be going on a civic if that makes any difference and I'll be using the Koni sleeves with my Yellows. I am looking to lower the car 2"-2.5". Will I be fine with these rates and the long front spring?
Old Mar 13, 2006 | 09:39 AM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">They will be going on a civic if that makes any difference and I'll be using the Koni sleeves with my Yellows. I am looking to lower the car 2"-2.5". Will I be fine with these rates and the long front spring?</TD></TR></TABLE>
If your civic in question is a 92-95, then you essentially have the same suspension as my 00 gsr, and I lowered 2.5" in the front on Koni Yellows with GC springs and GC top hats, and that literally set the shock on the bumpstop. I need to raise it back up. Don't be in a huge rush, make sure you leave yourself enough suspension travel at whatever height you choose.
And considering that I have a little more than 1" left on the threaded sleeve, you should be able to lower 2.5" in the front with a 9" spring, but without some kind of shortened shock or extended top hat, you'll be resting on the bump stops at that height.
beanbag
Suspension & Brakes
Sep 10, 2007 11:13 AM
KillaB-
Dec 25, 2004 07:43 AM
SkyeC
13
Jan 17, 2003 07:23 PM
743power
Mar 20, 2002 07:25 PM
InstantRamen
Aug 10, 2001 10:02 PM
