Koni Suspension? Do rears have metal rings over circlip
I just got a set of koni yellows for the 94-01 integra and installed the front, which have a set of metal rings that go between the circlip and the spring perch. The back did not come with these and I was just wondering if there was a mistake and they did not send them or if they are just not needed and the perch goes directly on top of the circlip. I tried searching and could not find an answer, any help is appreciated.
Re: Koni Suspension? Do rears have metal rings over circlip (Bobby808)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bobby808 »</TD></TR><TR><TD CLASS="quote"> I just got a set of koni yellows for the 94-01 integra and installed the front, which have a set of metal rings that go between the circlip and the spring perch. The back did not come with these and I was just wondering if there was a mistake and they did not send them or if they are just not needed and the perch goes directly on top of the circlip. I tried searching and could not find an answer, any help is appreciated.</TD></TR></TABLE>
The Back Spring Perchs capture the circlip, and do not need the metal "washer" for them to work correctly.
hella_usdm
Suspension & Brakes
05-24-2006 10:01 AM
