Suspension & Brakes Theory, alignment, spring rates....
Upper Ctl. Arm Bushing causing SHAKE?
Old Mar 28, 2006 | 02:19 PM
JDMPheens's Avatar
Default Upper Ctl. Arm Bushing causing SHAKE?
I have been having a shake in my wheel and actually my WHOLE car. It does it @ light acceleration and stops @ 60kmh. I just checked and my upper bushings are shot as ****. Could this be my problem?? Thanks in Advance
Old Mar 29, 2006 | 09:29 AM
PIC Performance's Avatar
Default Re: Upper Ctl. Arm Bushing causing SHAKE? (JDMPheens)
Yes, if the bushings or balljoint on your UCA are shot, then that corner is going to be a little shakey. While you're down there, check out your tie-rod ends and lower balljoint too, you might as well.
akos512
Apr 14, 2019 09:38 AM
henwon
Suspension & Brakes
Aug 26, 2010 07:03 PM
EFing8
Jul 19, 2009 11:19 PM
veganej
Oct 9, 2005 12:29 PM
essex
10
May 23, 2005 09:41 AM
