Suspension & Brakes Theory, alignment, spring rates....
lowering problem, help!!!!!
Old Apr 11, 2006 | 09:44 PM
dtran002's Avatar
Default lowering problem, help!!!!!
hey guyz, big problem about lowering....it a 2000 accord, coupe....anyway, as i try to remove the shock out of the car, it stuck and wont come down....here is the problem...i removed the bolt that hold the shock, and try to press the brake down so it would loose, one side, the front, got off easily and finish that one side in like 30mins, the other side, it wont come off, so i took off the bottom bolt, sorry, i dont really know what the thing call, it has two bolt, one on top to squeeze the bottom of the shock, and the second one to hold the lower arm???? anyway, after i got that bolt out, the shock push down, while the control arm, i think thats called, push up...no matter what i tried, the shock wont come out...any way to get this thing fix? sorry i hope you understand
btw, i did post this in accord forum, hope i dont get dink for 2post same topic cause this forum might be better
Old Apr 11, 2006 | 10:29 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: lowering problem, help!!!!! (dtran002)
The rears should come out by removing the two nuts located inside your trunk (#17 in the first pic), then you remove the single bolt that connects the Lower-Control-Arm to the bottom of the shock (#16 in the first pic)
The front shocks should come right out by removing all the top nuts inside the engine bay (#14 in second pic) and then removing the pinch bolt that attaches the shock to the damper fork (#22 in third pic). If the damper fork (#17/18 in third pic) is still in the way, just remove the tru-bolt (#24 in third pic) that connects it to the front Lower-Control-Arm (#7/9 in third pic) and it will drop down and out of the way.
If you still can't do it, you should take it to a mechanic...
Old Apr 11, 2006 | 10:39 PM
dtran002's Avatar
Default Re: lowering problem, help!!!!! (94eg!)
the pic help, well, the thing is im leaving the shock and spring alone, i just unbolt the bolt number 22, and 17 on the last pic, and that thing juss push down and stay down, while the control arm pushes up, one of the side, i juss remove those 2 bolts and twist off that thing and it come off, this side, it seem like the shock, number 4 on second pic, pushed down and it bent....is there anythin else that i can remove to losen the control arm so that it wont pushes up?
Old Apr 11, 2006 | 10:48 PM
94eg!'s Avatar
#1 Super Guy
Loved
EDIT**********
I don't understand how the control arm is pushing up. What is going on...
Old Apr 11, 2006 | 11:09 PM
dtran002's Avatar
hehehe, dats why im asking for help, the shock keep pushing down while the control arm pushing up, i couldnt find anything or think of anything that cause this to happen....
and when i tried to jack up the upside down U shape thing, the control arm go up with it, i couldnt find what pulling that up
Old Apr 12, 2006 | 01:03 AM
dtran002's Avatar
oh yeah, i did it one side at a time, so i jacked up one side do it, drop it and then raise it up the other side while the finished side is down, does that have to do anything that keep the control arm keep pushing up???? i didnt think that it matter and i didnt try to lift up both side at the same time
Old Apr 12, 2006 | 06:34 AM
CRX Lee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dtran002 &raquo;</TD></TR><TR><TD CLASS="quote">oh yeah, i did it one side at a time, so i jacked up one side do it, drop it and then raise it up the other side while the finished side is down, does that have to do anything that keep the control arm keep pushing up???? i didnt think that it matter and i didnt try to lift up both side at the same time</TD></TR></TABLE>
If you have jacked up one side and the otehr side is on the ground and likely compressed some, then if the front sway bar is still connected it will be trying to pull the control arm upward or at least resist you pushing it down.
Jack up the entire end of the car so both side of the front suspension are in dropp and your life will be much easier.
Old Apr 12, 2006 | 08:37 AM
dtran002's Avatar
Default Re: lowering problem, help!!!!! (CRX Lee)
hahaha i tried, it didnt work, now i gotta take out the axel to remove that thing look like the upside down U...anyone know what is the reason the shock keep pushing down?
Old Apr 12, 2006 | 08:50 AM
94eg!'s Avatar
#1 Super Guy
Loved
Can you post pictures to help us see whats going on?
Old Apr 12, 2006 | 09:30 AM
CRX Lee's Avatar
You are doing something very wrong as there is no need to remove the axle. Did you take the bolt from the bottom of the wishbone to the lower control arms out? This lets the wishbone drop down past the LCA. Did you remove the pinchbolt clamping the top of the wishbone to the bottom of the shock? This will let you remove the wishbone from the shock and remove it from the car and shock seperately. There will be no problem removing the shock and spring from the car without the wishbone on the shock.
You cannot (or at least it is very difficult to) remove the shock and spring assembly from car with the front wishbone still attached. Remove the bolts at teh top and bottom of the wishbone before trying to remove the shock and spring from the car.
Old Apr 12, 2006 | 11:47 AM
dtran002's Avatar
yeah i know how to do them...it just this one side is mess up...i took it to the mechanic shop, and we found out that the previous mechanic or whoever did the car, mess up the shock...it bent...so when i removed the bolt, it snap down and wont budge...the upside down U shape thingy, the place where the bottom of the shock go in (pic number 22 on the 3rd pix) is wide open, so we have to replace that thing...o gosh, hope i make some sense lol
alscrx
12
Jun 13, 2009 05:26 PM
305S0L
Mar 2, 2008 01:02 PM
eric8876
Apr 25, 2004 06:36 PM
