Suspension & Brakes Theory, alignment, spring rates....
Brake Pad Shims function
Old Aug 15, 2006 | 06:30 AM
lenjai's Avatar
Default Brake Pad Shims function
Hi fellow HT,
I have just changed my rear calipers, pads, rotors on my 94 Teg LS and realized the pads that I purchased did not come with the metal shims. Is it ok for me to drive without the shims installed or will it cause some serious damages on my new rotors and pads?
Thanks
Old Aug 15, 2006 | 09:37 AM
hayabusa160's Avatar
Default Re: Brake Pad Shims function (lenjai)
certain pads do not use shims what kind of pads did you buy
Old Aug 15, 2006 | 12:43 PM
lenjai's Avatar
Default Re: Brake Pad Shims function (hayabusa160)
I think they're called Duralast from Autozone. What is the function of shims?
Old Aug 16, 2006 | 01:10 AM
93CamaroLT1's Avatar
techniquely you are suppose to take the old shims off and put them on the new pads if the new pads don't come with them but its really not necessary, just spray some brake quiet on the back of the pads and it'll be fine. The purpose of the shims is to reduce the chattering/noise on the pads when the caliper hits the pad (brake quiet alone works fine) and also there is that indicator tab that makes that annoying *** screaching when your pads get low and thats about it.
Old Aug 16, 2006 | 10:44 AM
Tyson's Avatar
wheres the suspension tech?
Old Aug 16, 2006 | 02:11 PM
lenjai's Avatar
Default Re: Brake Pad Shims function (93CamaroLT1)
Thanks. I read somewhere the shims suppose to distribute the brake pressure evenly across the pad. Is that true?
PatrickGSR94
Suspension & Brakes
11
Oct 4, 2007 08:11 AM
Arsenal
Nov 30, 2006 12:50 PM
shadowdawn
Aug 1, 2002 04:06 PM
timbuktu
Mar 22, 2002 12:50 PM
