Suspension & Brakes Theory, alignment, spring rates....
does it make sense to do an alignment?
Old Mar 27, 2007 | 03:21 PM
Dutty D's Avatar
Default does it make sense to do an alignment?
yea i'm pretty low, and was thinking would it make sense to do an alignment. i have a camber kit but being that low can only have so much camber. but help me out here.
Old Mar 27, 2007 | 03:24 PM
Tyson's Avatar
Default Re: does it make sense to do an alignment? (Dutty D)
yes.
not even a question. you should get an alignment.
Old Mar 27, 2007 | 03:42 PM
Dutty D's Avatar
Default Re: does it make sense to do an alignment? (Tyson)
would it fix my tire wear. hopefully i'll wear it out evenly?would my tires last theirnormal life, cause i change tires every three months.
Old Mar 27, 2007 | 04:46 PM
Tyson's Avatar
it wont "even out" whats already uneven.
but an alignment is necessary to ensure your tires wear evenly from the start.
you wasted your money getting a camber kit and not even an alignment. you just needed an alignment to correct your toe.
Old Mar 27, 2007 | 05:38 PM
Dutty D's Avatar
true but is the toe adjustable? the camber kit came with the car. i can see your point though. thanks for the reply's, i'll get the alignment done.
Old Mar 27, 2007 | 05:53 PM
Tyson's Avatar
toe is always adjustable.
blkcivic310
11
Mar 11, 2010 03:57 PM
blackccoupe
Suspension & Brakes
12
Oct 18, 2009 03:53 PM
qhondak
Suspension & Brakes
Jan 31, 2008 08:07 AM
98GSRDC2
Suspension & Brakes
Aug 17, 2007 11:10 AM
bryandamatrix
Jul 10, 2004 12:32 PM
