Suspension & Brakes Theory, alignment, spring rates....
Simple question.
Old May 26, 2007 | 11:16 PM
HRD's Avatar
HRD
Default Simple question.
I'm still unclear about this. Is it bad to put say a 22mm rear sway on a 97 ek w/o subframe support?
Old May 26, 2007 | 11:20 PM
Milano Sol's Avatar
Default Re: Simple question. (Alex Trebek)
yes. EK has weaker design compared to EG/DC chassis.
on Ek/EJ/EM the lower control arm bolts are more towards the center of the car and the sway bar bracket mounting points are on the outside of those LCA mounting points.....it puts more stress thus leading to a weaker subframe.
ASR makes a fine kit to help cure this issue. pricey but from what i hear its worth it.
Old May 26, 2007 | 11:32 PM
HRD's Avatar
HRD
I too have heard great things about ASR braces. And I was confused between which chassis was weaker. Appreciate the quick response.
EDIT: What if I have a tie-bar? Would something like the ASR subframe brace be better? Or is it something completely different?
Old May 27, 2007 | 12:18 AM
Milano Sol's Avatar
Default Re: (Alex Trebek)
completely different. Tie bars just tie the 2 points where the control arms connect to the subframe. teh ASR brace is a subframe reinforcement brace.
the ASR brace eliminates the use of a Tie-Bar to an extent....and despite of what people on the boards here say, according to ASR from there website you CAN run a rear tie-bar still. it just needs to be installed after you install there kit with sway bar.
http://www.asrparts.com/
go to there FAQ section and its the 2nd to last question.....straight from the horses mouth
Old May 27, 2007 | 06:39 AM
Egezzy's Avatar
Spongebrad Squarepants
if u run the beaks kit/any subframe reinforcement not all tie bars are compatable.
Old May 27, 2007 | 08:47 AM
JunY's Avatar
https://honda-tech.com/zerothread?id=1718975
Rishiras
Mar 12, 2010 07:51 AM
Orientalbigboi
Sep 8, 2007 11:22 AM
heel_touge
Suspension & Brakes
Apr 13, 2007 09:27 AM
Smashback
Suspension & Brakes
Jan 24, 2005 11:48 AM
SuperMan19
Mar 17, 2003 02:25 PM
