Suspension & Brakes Theory, alignment, spring rates....
Spring compressor???
Old Jun 12, 2007 | 11:05 PM
EK4nut's Avatar
Default Spring compressor???
Does anyone know if you need a spring compressor to remove lowered springs (50mm) from an EK?
Old Jun 13, 2007 | 05:53 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: Spring compressor??? (EK4nut)
Non-sense, my brother and I duel at 10 paces with loaded springs.
Remember, you only get two shots. And springs are heavy, so much more than 20ft and you have to aim high.
Old Jun 13, 2007 | 09:09 AM
numbnuts22715's Avatar
I would say they can be helpful, but not necessary.
I have used them before, and I have not used them before... Either way works.
Sometimes with some springs, its hard to get the spring compressors between to coils because there isnt enough room between them.
If I were you, I would just be careful, and not use them.
Old Jun 13, 2007 | 09:27 AM
gabebauman's Avatar
Default Re: (numbnuts22715)
Lowering springs should not require a compressor to be removed from the shock assembly.
It's stock springs that are loaded while assembled on the shock and top hat. And Tyson tells me that it may just be the fronts that are like that.
Modified by gabebauman at 1:24 PM 6/13/2007
Old Jun 13, 2007 | 02:51 PM
EK4nut's Avatar
Thanks guys, i'll give it a try today!
HondamanXxX
19
Jun 21, 2007 04:30 PM
Dee A Nine
Suspension & Brakes
Aug 29, 2006 05:52 PM
Dee A Nine
Aug 29, 2006 04:27 PM
dungsta
Suspension & Brakes
May 2, 2005 10:34 AM
Understeer
Apr 1, 2005 11:32 PM
