Will these EF gc coilovers work on an EG?
http://www.importsnc.com/forum...23549
If I put an eg fork on these shocks will these bolt on to an eg?
I think you need the EF forks to make them work on an EG. The problem you will run into is that the EF shocks don't have enough stroke to work properly on an EG. This short stroke, and shorter front fork might not leave you enough droop to keep the front tires in contact with the road around corners. This will most likely result in excessive understeer. You could always give it a try though...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">I think you need the EF forks to make them work on an EG. The problem....blahblah balh... You could always give it a try though...</TD></TR></TABLE>
forget all that. the only thing useful for you is the ground control sleeves and springs. you dont want to to be using them on a STOCK shock, especially a EF shock on your EG.
and its only a pair.
for $100, its not a bad deal really. youre only getting a pair tho. and you should put them on some good shocks like illuminas. wasting your time with putting them on stock shocks, ef or eg...
