Suspension & Brakes Theory, alignment, spring rates....
Alignment/Toe question
Old Feb 1, 2010 | 08:38 AM
-iLLuZioN-B18C1's Avatar
Default Alignment/Toe question
I got an alignment last week on my mazda3. Went back this week to redo the toe in the rear and got the report back. My BEFORE (this week) is fairly different from my ACTUAL (last week), which should be the same correct?
For instance, my ACTUAL last week:
Left Rear Toe: .23
Right Rear Toe: .09
This week my BEFORE was:
Left Rear Toe: .11
Right Rear Toe: .16
Can things change that much within a week? Im confused. However my camber and caster did stay pretty much the same.
Old Feb 1, 2010 | 09:23 AM
Tyson's Avatar
Default Re: Alignment/Toe question
bad measurements...
or you have bad tie rods and play in your balljoints or bushings.
Old Feb 1, 2010 | 04:24 PM
Stonebender's Avatar
Variance in setup... the biggest change I see there is .12 degrees, which is hardly anything.
swizz977
10
Dec 23, 2011 09:07 PM
wannaBjdmca6
Suspension & Brakes
29
Jan 22, 2011 08:52 AM
huge230
Apr 8, 2006 05:22 PM
AzntaggeR
18
May 1, 2004 03:21 AM
01CWITR
Aug 6, 2002 05:32 PM
