Suspension & Brakes Theory, alignment, spring rates....
Function7 rear brace ??
Old Feb 15, 2010 | 05:05 PM
NyPosterBoy's Avatar
Default Function7 rear brace ??
Hey guys,
I just picked up the function7 rear brace and lca's for my em1. For any of you guys running this setup out there I was wondering which sway bar did you go with.. I tried searching for common setups but haven't found anything specific to that combo. I'm thinking of the ASR swaybar. Any advice is welcomed and appreciated!
Old Feb 15, 2010 | 07:14 PM
GagnarTheUnruly's Avatar
Default Re: Function7 rear brace ??
I would think any sway bar would be OK with any brace. Just get the diameter you want, which affects how much oversteer you're setting your suspension up for. ASR is 24 mm I believe and I think it's adjustable. ITR is probably the most commonly used and it's also the cheapest. It's 22 mm and will have less oversteer than the ASR (at least at it's 'stiffest' setting).
Old Feb 15, 2010 | 08:37 PM
alphalanos's Avatar
I agree with CTR/ITR. its perfect for the street.
Old Feb 15, 2010 | 10:03 PM
Thanks for the great info.. I'll go with the ITR Swaybar.. its much less expensive than the ASR. Which end links would you recommend? Can I use the OEM si endlinks? or would you recommend after market (ASR, blox etc)
Old Feb 16, 2010 | 05:56 AM
IMO factory endlinks are best, as long as they fit! Not sure exactly what you should do in an EM, but in my DC2 I just reused the ones that were in there. Aftermarket endlinks are $$ and can be noisy, or so I hear.
Old Feb 16, 2010 | 07:36 AM
wite2nr's Avatar
I have a jdm itr sway bar with my f7 rear brace. I used blox spherical endlinks and have f7 lca, it fit perfectly.
Old Feb 16, 2010 | 10:09 AM
Yeah I want to keep the stockies.. the ASR endlinks are 70 bucks wtf!
What kind of car?
EFstyle
14
Aug 23, 2007 06:18 PM
HybridIntegra
20
Nov 16, 2004 07:38 PM
Mr. Choi
Jan 17, 2004 04:06 PM
DeDonDeRosa
Jul 26, 2003 06:26 PM
yaksplat
Sep 18, 2001 09:32 AM
