Suspension & Brakes Theory, alignment, spring rates....
Endlinks, when to replace?
Old Feb 9, 2010 | 03:44 PM
OH_1fstgsr's Avatar
Default Endlinks, when to replace?
This past weekend I had to replace the endlinks on my 1993 Del Sol. The one side had completely broken off, 17 years old. While replacing both sides I notice how compressed and distorted the rubber pieces had gotten.
My question is now should I replace the ones on my 1999 GSR? If so should I use urethane or a different type of rubber?
Old Feb 9, 2010 | 04:56 PM
TunerN00b's Avatar
Default Re: Endlinks, when to replace?
When to replace? When the rubber is old enough to be visibly worn or deformed, or if it cracks.
Rubber or urethane? I'd go with rubber, simply because of how much deflection is required for the endlink bushings.
I think that most people who are that concerned about their ARB bushings, end up with spherical bearings instead of bushings, but those have a rather limited lifespan.
Old Feb 10, 2010 | 11:03 AM
Blindeye_03's Avatar
The endlinks on my ep3 are crap - one broke after an autocross (I also have a 20mm rear swaybar). I now sport a corsport endline and a stocker, so when I am unlazy ill replace the other but if youre on stock sway bars I wouldnt worry too much..
JC_1118
Jul 31, 2013 04:20 PM
hazard_one
Suspension & Brakes
23
Dec 13, 2007 10:29 AM
EG2Driver
Jul 27, 2006 10:14 PM
idriveadelsol7
Apr 29, 2005 01:20 PM
idriveadelsol7
Suspension & Brakes
Apr 29, 2005 10:16 AM
