Suspension & Brakes Theory, alignment, spring rates....
Replace my setup?
Old Jun 8, 2010 | 02:19 PM
Xathine's Avatar
Default Replace my setup?
I'm about to pickup another Del Sol and I'll be swapping most of my parts over to it.
My current suspension setup consists of:
-Extended GC Top hats
-Ground Controls (380 front, 450 rear)
-Koni Yellows
-Skunk2 F + R camber kits
-Suspension Technique sway bars (19mm front and rear I believe)
-ASR Subframe Brace
-ES bushings all the way around
-Skunk2 LCAs
I'm thinking about switching it up to F&F type 2s, with an ASR 24mm rear sway bar
The car will mostly be a DD (very aggressive) with some drag time and autocross mixed in.
What do you guys think? Or should I just pick up the ASR sway bar and call it a day?
Old Jun 8, 2010 | 02:32 PM
98civdx's Avatar
Master Detailer
Default Re: Replace my setup?
I would keep the koni/gc and loose the camber kits.
Old Jun 9, 2010 | 09:01 PM
Xathine's Avatar
Uh, why?
Old Jun 10, 2010 | 08:52 AM
98civdx's Avatar
Master Detailer
1. Koni/gc is so much better then functionform
2. Camber kits really aren't needed, skunk2 ball joints suck, and the rears creek and make all kinds of weird noises,
I had less then a 1000 miles on them and bushings were done and ball joint boots were torn to hell,
And the fronts increase the chance of slamming the uca into the shock towers
Old Jun 10, 2010 | 02:44 PM
mattq's Avatar
yep koni is much better
HuchNet
Suspension & Brakes
Jan 13, 2012 11:56 AM
Blacknight117
Suspension & Brakes
32
Apr 13, 2011 07:35 AM
therealeg6
Suspension & Brakes
16
Jul 8, 2009 02:18 PM
TypeRBoy
Honda Civic (2006 - 2015)
Dec 13, 2008 08:30 PM
