Suspension & Brakes Theory, alignment, spring rates....
Solution for torque steer?
Old Mar 16, 2011 | 02:45 PM
pocoek03's Avatar
Default Solution for torque steer?
Hey,
I'm planning out a turbo build for my EK and something that i've noticed even with the stock power is there is torque steer. Now not saying that my suspension couldn't be screwed but my apprenticeship teacher has told me that having the longer shaft will most definatly twist under alot of power. Is there a solution such as an aftermarket jack shaft so i can bolt on an equal length cv?
- Nick
Old Mar 16, 2011 | 03:50 PM
PreyStayShun's Avatar
Default Re: Solution for torque steer?
mmmmmmmmmmmm......I don't think I've ever been in a FWD car that didn't have some sort of torque steer upon full throttle.
RWD conversion perhaps? JK JK JK on a serious note, torque steer and fwd drive train go hand in hand in my opinion, my Acura has it, my Volvo C30 has it....
You may be able to reduce it a little, but I highly doubt there is a true "solution" for it.
Old Mar 16, 2011 | 04:36 PM
pocoek03's Avatar
the boots aren't torn, i may rebuild em just to regrease them and do an inspection and so on... but not damaged from what i can see
Old Mar 16, 2011 | 04:41 PM
Was thinking about this...... Here's a decent question which I don't have no answer to since I have no direct experience with the product.
Wouldn't a traction bar help significantly w/torque steer? Do I sound dumb as hell right now ht'ers?
Old Mar 16, 2011 | 05:15 PM
chialpha2006's Avatar
traction bar, LSD, remove power steering (if you have it- i'm not familiar with ek's as much)... and just get used to it, drive a high horsepower srt-4 and you'll thank your honda for not being as bad
Old Mar 16, 2011 | 05:18 PM
night's Avatar
corner balance would help if you happen to have coilovers.
Old Mar 16, 2011 | 05:38 PM
bluejcivic's Avatar
jdm zc DOHC motors use a jack shaft, it "should" fit your d series, there is also the usdm crx si with a d16a6 and it has a jack shaft, that one you could order it from Honda and see if it fits. good luck
Old Mar 16, 2011 | 06:48 PM
TunerN00b's Avatar
No clue on the accuracy, but wikipedia lists an LSD as making torque steer worse.
http://en.wikipedia.org/wiki/Torque_steering
Equalise the torque better between the driveshafts by using a low friction differential. The torque difference is zero if the differential is frictionless, and limited slip differentials, intended to increase power transfer, actually make torque steer much worse.
Old Mar 16, 2011 | 08:13 PM
LOL and everything on wikipedia is the truth right?? jk not trying to get into a pissing match with you on the internet, but from my experience - i've had both the kaaz and mfactory LSD - it helps... one wheel peel ftmfl
Lo-Buck EF
Apr 23, 2010 10:21 PM
gsrt2c
Jul 2, 2003 04:57 PM
rubens
Jun 1, 2003 04:43 PM
